Fibaro Universal dimmer to control fan
Would like to use UI5 and fibaro universal dimmer to control several exhaust fan system (IN and OUT) for a hydroponics garden and build a zwave climate control room
The fans are now being control by climate system with a temperature sensor built into a fan speed controller.
I planned to convert and build that system using seperate temperature sensors and UI5 to trigger a scene to control the fan speed, light etc.
Can a fibaro universal dimmer (leading edge) support a 100w exhaust fan ? Seems like it could on some posts but its not very clear. Usually on leading edge dimmers that can support exhaust fans, the coils are much larger.
Even between 100watt to 300 watt halogen lighting system, the fibaro dimmer heats up.
Simply put you should never ever use a dimmer with a fan. You will burn the motor and possibly cause a fire.
  • Garrett
Well, Theres leading edge smooth rotary dimmers thats specially made for fan
Legrand makes one thats support up to 400va
http://www.legrand.com/ecat_export/283081-rotary-fan-control-mallia-400.html
Clipsal makes a fan speed controller and universal dimmer that supports motor fans too. Their universal dimmer will run the motor at high speed than reduce to low speed as not to burn the motor during startup.
I have tried the legrand switches but it doesn’t reduce the load lower than 40va so not applicable to this system
With the fibaro dimmer if it does support up to 500w then would it be able to support a small motor ?
