Situation:
Me zwave / vera Noob this is my first setup
Vera Edge running the latest version: 1.7.1089
Fibaro Universal Binary Sensor with default settings
Connected it with the Vera and it detects 3 devices
Universal Sensor
Universal binary input 1
Universal binary input 2
Connect blue wire with the yellow wire and connected blue with green but the GUI doesn’t show it detected motion.
[quote=“sfxfreak, post:2, topic:187046”]I have the same problem you are, but it looks more like a general problem with Vera not working well with the sensors since a couple updates.
To downgrade your unit please follow these instructions :
connect to Vera?s interface
then go to Settings and select Firmware
and copy paste the URL below in the firmware field and hit ?download?. http://builder1204.mios.c…-1.7.961-en-mios.squashfs
when prompted select to downgrade your unit with ?keep settings.?
the downgrade can take up to 15-20 minutes and you shouldn?t unplug Vera in that time
Note: The downgrade should be done from the same location as the Vera uni
Your link didn’t paste here properly, but if I am not mistaken - it won’t help me.
I also have the 3in1 Fibaro sensors and previous firmware versions don’t support it properly.
[quote=“sfxfreak, post:4, topic:187046”]Your link didn’t paste here properly, but if I am not mistaken - it won’t help me.
I also have the 3in1 Fibaro sensors and previous firmware versions don’t support it properly.[/quote]
I have just downgraded with the link you supplied and relearned the device but still no joy.
Do you add it as a generic zwave device or something else?
I did and they promised it would be fixed in the October release.
take a look at this thread, apparently MCV is fixing the issue individually per submitted ticket
[url=http://forum.micasaverde.com/index.php/topic,32320.15.html]http://forum.micasaverde.com/index.php/topic,32320.15.html[/url]
