Hi. I have three Fibaro Smoke Sensors FGSS-001 and all are connected to a permanent 12v power supply. All are connected to my Veralite V1.7.481 and appear to work as expected.
What I’d like to do is when one alarm detects smoke the other sensors also sound the alarm. i don’t have a secondary central fire/alarm system so I need this to be wireless.
As an aside I’d like to test the alarm remotely, without pressing the button if possible.
[quote=“Zeno99, post:1, topic:185418”]Hi. I have three Fibaro Smoke Sensors FGSS-001 and all are connected to a permanent 12v power supply. All are connected to my Veralite V1.7.481 and appear to work as expected.
Thanks[/quote]
I also searched for this. Can’t find a way to do. Anyone?
It seems, that linking multiple sensors in a way, that all sensors siren when only one of them senses a fire isn’t possible with these Fibaro smoke-sensors. On the fibaro-page (Smoke Sensor | FIBARO Manuals) under support FAQ 7 one can read:
How can I trigger the siren remotely? What is the command class to be used?
It is not possible. This device is the sensor only, not a Z-Wave siren.
I installed 4 First Alert Combo units sometime ago and wanted to do the same thing. I could not find a way to get Vera to cause the any of the units to go into alarm and sound the horn.
