Fibaro shutter control inverted after shutter repair
I have 3 Fibaro shutter controls. After the repair of one shutter the Fibaro now shows that one in Vera as inverted, i.e. when it is shown open it is actually closed and vice versa. How can I fix that?
What do you mean by repair? Have you de-installed, installed and callibrated the Fibaro again?
The shutter broke and the company installed a new one. All this was exterior work. The manual wall switches still work as before, only VERA thinks that the shutter is open when it is closed (down).
You should just invert the wires on O1 and O2 of the Fibaro. Depending on the wallswitch you have, you may will even invert the wires on S1 and S2 of the Fibaro.
Thanks - that is probably the simplest and best solution! I will try this when I am returning to my vacation home in a couple of weeks …
