My electric roller blinds installer (Somfy) has suggested I add the Somfy Dry Contact module. They said this is used by all the HA installers to
integrate Somfy motorized blinds easily into their systems.
I was wondering if any one could shed some light on whether the Fibaro Roller Shutter module would wire into the dry contact module it and work without a hitch?
The PDF for the Somfy dry contact module is here:
And some info at:
And the Fibaro: http://www.zipato.com/UserDocsImages/Fibaro/Fibaro%20roller%20shutter%20FGR221_inc_exc.pdf
I know I could go to the ZRTSI route, but I’d rather use the Fibaro modules as I have blinds on two floors and FWIW, the modules will act as repeaters as well to create a more robust mesh.
