Fibaro Roller Shutter Control to iVera Apps
Hi Guys
I have problem for my fibaro roller shutter in ivera apps please help, when I press the open button my curtain is closing and pressing the close button it will open, what will i do for this?
Thanks…
Inverse the motor wires on the z-wave device.
Roy.
Is there any other way i can do that by a software?
Like a parameter or sth?
[quote=“therealabdo, post:3, topic:173517”]Is there any other way i can do that by a software?
Like a parameter or sth?[/quote]
You might hit up Tech Support as they had planned on giving us a variable for window coverings to toggle up/down open/close polarity. Otherwise you might be able to modify the Implementation file for the Window Covering device and switch up/down there.
