Hello,
how can I change the default “Switch Type” of the Shutter to value 1 ?
Thank you,
Axel
Hi Axel,
You need to go the Vera UI – Open the Device tile, and Open the “Device Options tab”.
Here you need to “Add a Configuration Settings”, choose 14 as variable, choose 1 byte hex as DataSize … and specify 1 as the desired value.
Note that I have experience issue with polling, and I set it to never. ( at this stage all is working fine in my side - using SOMFY electron motor ).
I’ve attached 2 screenshot regarding - with switch type / polling
Didier
