Fibaro Motion Sensor FGMS-001 and the Accelerometer
Should the accelermoter sensor be exposed in Vera Edge. I see motion, temp and light sensors exposed.
No, it will not appear as its own device, but some of the values are reported in the advanced tab of the main motion sensor called so_tamperalarm and lasttamper.
You can also change the behavior using parameters 20, 22, and 24 from the manual
But in general there is very little support for it, best bet might be to use PLEG to monitor the variables if needed.
@Shallowearth - Good information. Thank you!
