Fibaro FGS221 2x1,5kW
just got the switch so i thought i start this topic for examples what one can do with it.
there are multiple possibilities with this device and i like to see what can be done with it and how to use it in a normal daily life.
Links:
http://www.pepper1.net/zwavedb/device/337
http://www.fibaro.com/files/instrukcje/eng/relay%20switch%20FGS221%20v19-%20v110%20ENG.pdf
Parameters used (1 byte Decimal) :
1 - All ON / Off
3 - Auto off relais manual override
4 - Auto Off relais 1
5 - 2
6 - Commands for group 1
7 - 2
13 - bistable key status
14 - Switch type : momentary or toggle
15 - Dimmer shutter control
16 - Powerfailure savestate
switch 1 switch 2
30 40 General alarm set
31 41 alarm flood/water
32 42 alarm smoke
33 43 alarm temperature
39 - 600 ms Flashing time
options for 30-33 and 40-43
0 - deactivate
1 - alarm relay on
2 - alarm relay off
3 - alarm flashing
groups :
1 - devices assigned to group 1 , key “S1”
2 - devices assigned to group 2 , key “S2”
24 volts
the device can operate with 24 volts and have 2 separate output which can handle 6A either 24v , 110v or 220/230v
which means you can also use it in a boat installation. very handy.
it is also usable for automation a door-intercom system.
the in- and output are separate from the device-power , so with some help from a transformer or a relais we can make it control the doorbell and the opener.
setting the alarm frame of the device to flashing turns the doorbell into a ringing alarmsound. cool !
220 volt
using it to control motors lights or other stuff
220v input bridged to 220v powerline of the device > turn on off 220v devices.
ceiling light with 2 bulbs :
open ceiling light and the box above it too. detach the (brown/black) wires to the lamps. put in O1 and O2. put brown wire in “IN” and attach this to “L” .
detach blue (neutral) wire from lamp and put this on “N” , from here you put blue wire to the bleu wires connector in the box.
detach 2 wires that goto switch and put these on brown on “L” and black on “S1”
using the alarm status
set the alarm you want the fgs221 to respond to : parameters 30-33,40-43. it default to flashing on normal alarm and off for water alarm. watersensor give wateralarm, smokesensor give smokealarm, doorsensor give general alarm. temperaturesensor give temperature alarm.
set the time you want to last the alarm status : parameter 39
in a door/window sensor find the group which belongs to alarm. set in this group the fgs221.
make sure you did not put a drill or similar to the output of fgs221 since it will start flashing > putting 220v on it or other voltage u put on “IN”
using it as remote control
when you alter the device properties and set a group to 1 and set a device with it, you are able to control this other device with the key number 1
setting a group 2 and in there a device would control the 2nd key and devices set in this group
so tap a wire from the “L” to the s1 would activate key s1 and also send a “on” command to the devices you put in the group 1
same with s2
Doorbell
using it as control for the doorbell.
the normal powerline adapter from the doorbell uses 220/110v input and has 8 or 12 v output, the power of the fgs221 will come from the 220 V/110 V side.
so we connect “N” & “L” to the 220V side of the doorbell-transformer. Since the fibaro got dry contact relais we do not need to take the other voltage in concern and are able to
connect the “IN” to one side of the 12V/8V output on the transformer and the “O1” to the other side on the 12V/8V input on the doorbell. or just cut 1 wire to doorbell and put one side on “IN” and the other on “O1” In simple language : goto doorbell transformer > find wire connected to output on it > cut 1 of the 2 wire > attach 1 side to “IN” and the other side to “O1” .
Now we have “O2” output left to use. we can use it to turn on or off another doorbell or 12V/8V device. Remember since we did attach 12V/8V to the input there is the same voltage on both the output.
doorbell pushbutton
We can do 2 things here. use a doorbell with double contacts (yes these exist) or detach the doorbell-button from the installation.
doorbell with double contacts : use the free 2 contacts and attach these to “L” and “S1” (dont forget you put 220v/110v on it so its not a kids-toy)
doorbell with single contact : detach the wires going to it , since it got 220v the wire is to small and most important : made for low voltage installation. Attach new 220v wire to doorbell (it can handle the little mA load) and attach these to “L” and “S1” (dont forget you put 220v/110v on it so its not a kids-toy)
door opener / intercom
using a relais we can switch anything that has 2 wires on it.
attaching a merlin gerin multi 9 TL to the output means we have 2 dry contacts on the other side which can handle 16 A and have any voltage till 250v
so if we go look for the button which you push to open the door, there are 2 wires behind it. put 2 wires more on both contacts and attach these to the 1 and 2 terminals on the merlin gerin.
Do keep in mind that it is a state-change relais, so it will change to the opposite position everytime its powered. A normal version can also be used. since a relais is a load you dont have to worry to shortcut anything. just keep in mind that the fibaro only switches 1 (V+) wire. so do use it parallel to for example a pushbutton. do not attach live and neutral to the same input&output.
the contacts of the fibaro could also be used for this if you have a normal domestic intercom interface. open the intercom box and find the connecting rail in the middle. look for the wires that go to the pushbutton. (to be found in the manual of the intercom) and attach two more wire to it. these 2 wire go to “IN” and “O2”. since most probably it has no power over the wires or we do not know this, we cannot use the other output just to be safe.
see attached picture how you would do such thing. i used 220v input and connect the “IN” to one side of the pushbutton and the “O1” to the other side.
now we do not wish to activate this when all on all off command is used so we set parameter 1 to 0. we do not need manual override so we set parameter 3 to 0. we do need the function auto off relais. it is handy so we use it. no scene or luup or other cpu demanding stuff just let the fgs221 handle it. so we set parameter 4 to 5 seconds which is in millisecs 50. we do not need to have it automaticly turned on in case of power failure so we set parameter 16 to 0. we do not need alarms but perhaps smoke alarm (auto open door in case of fire ^^ ) so parameters 30,31,33 to 0. for auto-open door case of smoke parameter 32 to 1 >relais on since we do not want it flashing. parameter 40,41,42,43 to 0. parameter 39 to the set time in ms for the alarm duration.
summed up:
1 to 0
3 to 0
4 to 50
16 to 0
30,31,33 to 0
32 to 1
40,41,42,43 to 0
connecting a sensor
in the local DIY you can get a simple PIR sensor with 220v input and output. probably you have one in use allready. to attach these we are going to do some trickery.
attach the inputs of the PIR to the mains and to “L” and “N” on the FGS221. connect the bleu/neutral/“N” to the lamp. attach the outputs of the PIR blue to “N” (or just leave it away) and the brown/Live to FGS221 “S1” and a brown/live from “O1” to the lamp.
Pilot Wire
thanks to Antor we can control a heater using the pilot wire of it. look here for details : http://forum.micasaverde.com/index.php?topic=9277.0
Honeywell heating system
http://upload.wikimedia.org/wikipedia/commons/8/8c/Honeywell_thermostat.jpg
you can use the fibaro to control the heating also. 24v or 220v. it does not use pulse, you need the pilot wire for this.
if you look inside the old honeywell and you see 2 strings of wires you can do this. if more then 2 wires are used you need a z-wave thermostate.
connect the left wire to the “IN” and the right wire to “O1” and the “L” and “N” to a 220/110v mains.
if you have a long wire running to the heater itself it is wise to take out the resistor of the honeywell and put this in series with the switch. i.e. take out right wire>connect to resistor>resistor to O1
if you have the 3-wire thermostate setup with 24v on it (you can measure this) it probably can also drive the fibaro and switch it.
you would need to also attach a dallas temperature probe to connect to the fibaro (flat side up, pins downwards, left is neutral, right is plus)
install the plugin for virtual thermostate from the market and set the tempprobe and the pilotwire to fibaro switch.
for better tempcontrol you could use a other tempprobe on the other side of the room.
u could also use the 2nd S2 key to manually override or attach a sensor. this could be usefull to automaticly override the installation in case of fire or open doors.
was so under the impression of the device you forgot you needed a 3kW switch
well just attach the S1 to S2 and the O1 to O2 and voila u have a 3kW switch. in vera dashboard use child device to control and make group 2 on child device and put in father device. I.E group 2 (child device) control also main device(father device).
W.I.P. i will add more when i have time.
The Fibaro FGS221 and its single-relay brother FGS211 are brilliant little devices. The design is very well thought through so they can be used for many different purposes. The floating relay contacts and configurable parameters give great flexibility.
I now use these devices for all my Z-Wave switching. They are small enough to fit behind a UK switch plate as long as the wall-box is 35mm deep (and not too full of cables). I have also installed some in 25mm wall-boxes using a 10mm spacer for the switch plate. This is not perfect but does not look too ugly.
I use the association feature to link some directly to Z-Wave thermostats (Horstmann HRT4-ZW) which works very well. The others are controlled from Vera using PLTS and PLEG logic plugins and scenes.
The first units I installed were single relay FGS211 types. Then I realised that the two-relay FGS221 units were the same price and size so, unless I need to switch more than 1.5kW, I use them for everything. Even if I don’t need the second relay, the fact that both switches send instant status to Vera when they change is an advantage.
I find it really useful to be able to configure how they respond to the switch inputs. I usually use the original bi-stable on/off wall switches and I like the relay to follow the switch - down is on, up is off - unless overridden by Z-Wave. This just requires configuration parameters 13 and 14 to be set to 1.
I have not yet needed the pulse output, roller-shutter or alarm features but I have no doubt that I’ll find a use for them one day.
If your thread is going to contain all the uses of these excellent little modules it is going to be quite long. Perhaps you should have a thread for the things they cannot do. ;D
They really are very thought through indeed. When i bought them i had no idea that it could do a lot more then one would think at first look, so thats why i have put this topic up so we can get a idea of what you can do with this device beyond the normal operation. for most people attaching it to their own installation is a challenge, even for me as master in electric engineering lol . so i try to put as many information as possible so we can all benefit from it and have some reference for possibilities one might not even had thought about. Since you incorporated the sensor part a lot i and others appreciate you elaborate more on this. like how you connected these and the parameters you used for it and the purposes it serves. And yes it is going to be long hehe but worthy.
Interesting… I chose momentary switches for just the reason that I hate momentary switches showing the wrong state if the switch has been changed by Z-Wave!
Monostable (momentary) switches are also especially good in multiway situations since you can just wire them all up in parallel. In fact, over the standard 3-wire connection used for a single secondary switch you can wire two momentary switches (one wire for common, one for each of the switches) - ideal for n-way control of the dual fibaro relays.
I have four pairs of switches at various points in the hall/landing all controlling two sets of lights through a single fibaro dual-relay module.
The biggest challenge I have faced in using these modules is getting them and the wiring into the wall box. There are seven connections on the FGS221 if you use both relays and both switches. The wire receptacles are quite small. They will take a single 1.5mm[sup]2[/sup] solid-core wire but not two. With seven solid-core wires connected I found it pretty much impossible to maneuver the module into the wall box. My solution is to use connector strip (used to be called chocolate-block in my youth) to terminate the solid-core house wiring and then use short lengths of flexible, stranded wire running from the connector strip to the module. This makes it much neater and considerably easier to insert and position the module. In lighting circuits I use 6amp connector strip and 1mm[sup]2[/sup] flexible wire. In power sockets I use 30amp connector strip and 2.5mm[sup]2[/sup] wire. I get the wire with appropriate colours by stripping short lengths of 5-core flexible cable - normally used for connecting boilers and heaters.
When mounting the module it is worth taking care to position the antenna wire. Most of my modules are mounted in steel wall-boxes but, by making sure the antenna wire lays behind the plastic switch plate, I have had no problems with communications.
Once I have added the module to Vera, I open the Device Options tab and add configuration settings for parameters 1, 3, 4, 5, 13, 14 and 16. To start with I set these for Monitor Only. Then after performing a Vera Save and browser reload, I check the values. Usually they are the correct default values as noted in the instructions but I have had the odd one that is not. Now, for the few that I need to modify, I change Data Size to 1 byte dec and enter the value I want. Then I go to the device Settings tab and click Configure node right now. One more Save and reload and it should be fully operational.
The parameters are fairly well explained in the instructions that come with the module. These are the ones I generally check and/or modify:
[ul][li] 1 - All On/AllOff response. 255=AllOn & AllOff (default), 0=Neither, 1=AllOff only, 2=AllOn only[/li]
[li] 3 - Auto Off mode. 0=Neither (default), 1=Switch1, 2=Switch2, 3=Both (Version 1.4 to 1.7)[/li]
[li] 3 - Auto Off manual override. 0=Disabled (default), 1=Enabled. (Version 1.9 to 1.10)[/li]
[li] 4 - Pulse length for Switch1 Auto Off 1 to 255=10ms to 2.5s. 0=Off (default)[/li]
[li] 5 - Pulse length for Switch2 Auto Off 1 to 255=10ms to 2.5s. 0=Off (default)[/li]
[li]13 - Relay Action. 0=Change state when switch changes state (default), 1=Follow switch (On=On, Off=Off)[/li]
[li]14 - Switch Type. 0=Monostable, 1=Bistable (default)[/li]
[li]16 - Power Fail Recovery Mode. 0=Set to off , 1=Set to saved pre-fail state (default)[/li][/ul]
When I want to associate a module with a sensor - Thermostat, Motion-Detectors, etc - I do it through Vera from the sensor device’s Device Options tab and Add Group. The Group ID depends on the sensor. For the Horstmann HRT4-ZW it is group 2. Then I click the Set button and check all the modules I want to be directly associated. After the customary save and browser reload, it should all be set and ready to go.
Most of my modules are controlled by PLTS and PLEG plugins and I take their current state as triggers for timers and set the relay states according to fairly complex rules depending on whether I am home or out, on vacation, getting up early, etc. The FGS221 is great because it reports change of state through local switch action instantly - well very quickly. :slight_smile: I am using this feature in some of my light switches so the second switch is just an input - the relay output is not connected. For example, the second switch on my bedroom light signals that I am getting up early tomorrow so I want a warm house and hot water at the time preset in the master timing PLEG device.
I honestly can’t fault these Fibaro switches. They have handled every one of my requirements so far. It would be nice if they were a bit cheaper but, they are so flexible, I don’t begrudge the cost. I always keep a few spare modules ready for the next inspiration. 8)
Rumor has it that Fibaro are planning to ship a US version of these modules soon. You guys are gonna love them! ;D
Interesting... I chose momentary switches for just the reason that I hate momentary switches showing the wrong state if the switch has been changed by Z-Wave!
The great thing about Fibaro switches is that we both get what we want by setting a couple of config. parameters. 8)
[quote=“RexBeckett, post:6, topic:174627”]
The great thing about Fibaro switches is that we both get what we want by setting a couple of config. parameters. 8)[/quote]
indeed !
and even more since we exchange the momentary/bi-polar switches with a sensor and let this do the switching or even use it separate from the output relais.
seriously there is a genius at work there at fibaro, there technical ingenuity is far beyond other competitors in the market and there skill is levels above them.
Sorry for the stupid question, but I’ve the FGS221 with 2 buttons schema for the same lamp (see attached image). Do I have to modify a parameter in order to work ? Monostable, bistable ? Where is this parameter? Thanks!
I hate to be the bearer of bad news, but an FGS221 is a dual single-way switch while your schematic shows two two-way switches. I’m afraid there is no configuration parameter that will solve this incompatibility.
ok, and how do you call this configuration? see picture.
I don’t know what to call it but it isn’t the same schematic you posted earlier.
ok, I didn’t say it was the same schematic. I’ve seen on another forum that this schematic was working fine with FGS221. So my question is will it work by default or do we have to modify some parameters to run with this schematic?
If I understand your wiring correctly, you have three switches connected in parallel between power live and S1 on the FGS221. I am assuming all three switches are momentary action. In this case you would need to set parameter 13 to 0 and parameter 14 to 0. Other parameters should be OK at their defaults but check them. P1 = 255, P3 = 0, P4 = 0, P5 = 0, P6 = 0, P7 = 0, P16 = 1.
The parameters are viewed/changed on the Device Options tab of the main (lowest device ID) device. You add a line for each parameter by clicking the Add configurations settings button and then changing the Variable field to the parameter number you want to view or set. The Data Size pull-down will default to Monitor only which is fine to check the current values. When you want to change a value, set the Data Size to 1 byte dec and put your required value in the Desired Value field. You can add lines for all the parameters if you wish.
To show/set the variables, move to the Settings tab and click Configure node right now. You should see some messages appear at the bottom of the device block - close the dialog to see them. When this has stopped, click Save, reload your browser page and then check the variables on the Device Options tab.
RexBeckett, Thank you very much for your valuable explanation. It helps, I will try. In fact, I have 2 switches but it will change nothing. The picture with 3 picts I’ve found it on a forum (french sorry). http://maison-et-domotique.com/blog/product-review/zwave-test-des-micro-modules-fibaro/
what u want to make is a hotel-switch ?
i think it should work, but it requires coding on the vera.
set 1 dual-switch to enable output 1 and the other also on output 1 in a scene . you need mono-stabile , if you want it to switch it with bi-stable it requires a triple wire switch which i dont think it exists. if key 1 pressed > output 1 enabled, output 1 on other fibaro enabled.
why not make it mono-stable and set the two lightswitches in 1 line to keyinput 1 ? that way u use 1 fibaro and it be much easier to understand lol
Thanks for all the info. I am evaluating one switch for now. It is connected to an outside lamp. (Just first switch connected.) I would like to have the outside lamp to automatically switch on/off at sunset/rise. I have that figured out. However, I would like to play around with the switch to turn on/off other devices or to execute a scene without controlling the relay/outside lamp…
When playing around with “group id 1”, it always add itself to the group, which means that the switch will turn on/off the relay.
So, it there anything I can do?
I ran across this site today looking up this switch. Unless the site is wrong, it appears that there is a US compatible version of this switch (switch from Spanish to English to read):
http://zwavedo.com/FIB_FGS_221
It is the Dominican republic version of this site. (you can also find this site in at least one S. American Country as well, branded for that locale)
Unless there is a typo, the frequency used states 908 Mhz.
Here is what the site says:
Radio controlled Fibaro Double On/Off Relay Switch is designed to be installed in standard wall switch boxes, or anywhere else where it is necessary to operate two independent devices of 1,5kW combined power output. Fibaro Double On/Off Relay Switch can switch on or off connected devices either through radio waves or through the wall switch connected directly to it.
Product Highlights:
? Controlled through other Fibaro devices or any Z-Wave controller,
? Microprocessor controlled,
? Our ON/OFF Relay Switch is the smallest device of the type in the World!
Technical Data:
? Power Source 110V - 230V +/-10% 50/60Hz, ? Max. single AC output: 8A / 230V 50/60Hz, ? Max. single DC output: 8A / 30V,
? Max. combined power output (resistive loads only) - 2 x 1,5 kW (in case of loads other than resistive it may be necessary to connect lower output in order to protect the Switch from damage),
? Conforms to UE requlations:EN55022 (radio wave interference), EN61000-6 (safety of use),
? Overheating protection: safety off at 105?C
, ? Ambient temperature: 10oC - 40oC,
? To be mounted in standard wall switch boxes fi ≥50mm,
? Radio protocol: Z-Wave,
  • ? Radio Frequency 908 MHz,
? Antenna range: up to ca. 50 meters outdoor, or up to 30 meters inside (depends on building structure),
? Outside dimmensions (L x W x H) 42mm x 36mm x 15mm.
Anyone willing to try getting one to see if it works?
What I never have figured out, do you need an additional wire from the Electricity cabinet? Does anyone have a clear picture with the central wires to the switch, to the FGS221 and the light bulb?
from mains cabinet to fibaro you need a live wire and a neutral thats all
light Live wire attached to output 1 or 2 of the fibaro and neutral wire from light goes to neutral on the fibaro/mains
I have the same question. Normaly, the switch input is controlling the relay. In some situations this is nice, but in a particular case I need to read the switch status (have the module report changes to Vera Lite controller) and control the relay from my Vera Lite controller. I don’t want the switch-input to have any direct influence on the relay status. Is that possible?
