I have a Fibaro Relay Switch FGS-222 that I want to install in Vera. How do I do the pairing and how do I set the switch for the 2 channels AND I use push buttons (toggle) and not normal switches.
Thank you in advance!
Hello, did you get this setup working. I tried the other day and it did not pan out as expected. But it was also registered as a fibaro single switch. So I’m all ears and hope you found a way to get it working.
