Does anyone have any tips for fitting the thermostat into the fibaro FGK unit ? Just got both units and it looks light a tight squeeze, is there a knack to doing it ?. Looks like it would be easier if the board came out.
Any tips gratefully received as it looks like there should be a knack.
It looks like the sensor could fit inside the unit to keep it nice and neat, has anyone got it in the housing or has everyone got it external ?. I thinking of testing this to monitor the temperature in the fridge so if it can fit in the unit it will keep it nice and neat.
No you dont want the unit in the fridge. buy a temp sensor with a cable and keep the unit outside the fridge and just put sensor inside.
At least you could provide a reason for your opinion. I don’t agree with you.
My Sensor is running just fine in the fridge, battery running just as good as non-cooled devices. This also allows me to get notified if the door of the fridge is left open from the same sensor without having to to any modifications to the fridge at all. It is no problem to get the DS8B20 sensor into the fibaro device itself. If you want to buy external sensors, have a look on eBay, the waterproof ones like above are available for arround one Euro.
My Sensor is running just fine in the fridge, battery running just as good as non-cooled devices. This also allows me to get notified if the door of the fridge is left open from the same sensor without having to to any modifications to the fridge at all. It is no problem to get the DS8B20 sensor into the fibaro device itself. If you want to buy external sensors, have a look on eBay, the waterproof ones like above are available for arround one Euro.[/quote]
Only reason I say that about placing unit outside and run sensor inside is i have always heard that batteries degrade much faster in a cold climate. Also I assumed the unit would not transmit as far from inside a metal box. And one last reason is if condensate forms on the circuit board on the unit it might cause damage. I have temp sensors on all of my fridges and freezer and just run the cable in thru door opening, no modification. I did buy 20 sensors from ebay with 1 meter cables.
OK, the metal box is a good reason, I don’t have any problems since all my fridges are fully out of plastics.
I have multiple sensors in fridges since my vera is regulating my fridge temperatures (Home Brewing), so far I have not seen any negative effects on battery life, but I have only lived in my new home fo about a year, so it might be a bit early to conclude about the batteries. Some of the fridges are running in between 0 and 2 degrees celsius, so quiet cold.
However, I like to mount them inside (with double sided tape). The white ones almost “disapear” since they look like built in sensors. And as already mentioned they also surveilance my fridge doors, but I am sure there are possibilites to make this work outside too.
To add something usefull for other users: I can confirm that the cheap DS18B20 sensors of ebay work just fine with the fibaro sensors (I use them to track the actual beer temperature).
To OP:
I added a terminal block so as not to damage the fragile and tiny connectors/screws in the Door/window sensor. Any problem I can undo at the terminal block. (See Photo)
Temp. sensor is to monitor temperature in the roof cavity.
Roof temp. is normally between 2 to 4 deg. Celsius higher than outside.
The reason I use the Door/Window sensor is for my solenoid door bell.(As suggested by Richard Schaefer in some Door Bell thread)
Light comes on when door bell rings at night. Temp. sensor was an add-on bonus.
Anyone know what config setting to make the Door/Window sensor more reponsive?
Seems to be a sleep at the first few ring of the bell.
Insert the three leads into the proper terminals and tighten the screws. Then just bend the sensor over so its inside the unit. Then fit the cover back on.
Thanks, took another look as have had more time today, was reasonably easy in the end to get the sensor to sit in the space at the end of the device, it just looked like it would be more tricky than it was.
Another question that I can’t find for searching the forum. The temp prob only seems to display in whole degrees, however the manual suggests that as standard it’s set to show increments of 0.5 degrees. Can’t see any settings in the unit itself either.
Is the resolution in whole degrees when using vera ?
