Fibaro FGD212 firmware update
How can I update a zwave plus device like the Fibaro FGD212 to its newest firmware ?
As far as I can tell… no.
I tried contacting Fibaro suppor about this, but the only advice was “RMA it”
Despite that, it clearly states in the marketing material (all of page 15) that this is possible. [url=http://www.fibaro.com/files/presentation_dimmer2.pdf]Wireless Smart Home and Home Automation | FIBARO - but it looks like they do not make it possible (even for owners of HC2).
Very annoying to have to have to re-order, unwire unpair, rewire, pair, update vera.
Not sure if this helps, but I’m trialling a Popp Hub, which has an update feature for device firmware.
It appears to be a function of the Hub/Controller in which you can select the device you want to update.
You then click on Update and …well who knows as I don’t have any Gen5 devices to test it on…
Not having a gen5 vera also makes it difficult as I have no idea if this feature is available.
