Fibaro FGD211 2nd button as scene selector
From version 1.9 this dimmer can send scenes by setting parameter #41 to 1. Unforunately Vera doesn’t seem to know about this. I’m not able to choose scene activation as trigger from the dimmer. This should of course be possible now with the added functionality of the dimmer. I’ve successfully managed to configured this with the Z-Cloud of Z-Wave.Me so it should definitely be technically possible.
What I’m trying to do is have a 2-button monostable switch (ELKO) where left side is the regular on/off+dimmer function while right side lets me choose between up to 4 scenes by holding (ID 22), clicking (ID 26), double-clicking (ID 24) or triple-clicking (ID 25).
Rgds,
Vidar
I was wondering about this myself as well. From the documentation of the device it looks like it can be used to trigger scenes, it would only need the correct implementation on the Vera side as well.
I am stuck at how to get my Veralite to respond to the S2 scene command from the Fibarop Dimmer too - any help?
http://forum.micasaverde.com/index.php/topic,15855.msg200101.html#msg200101 shows you how to do it for S1, (Double-Clicking has an ID of 14).
http://forum.micasaverde.com/index.php/topic,15855.msg135492.html#msg135492 has an ID list for S2.
