Sorry for the late reply guys, I don?t check the forum that often.
Last weekend 2-3 December I removed 2 of my FGBSs and then re-introduced them both with 3 temperature probes each. One setup in my main summer house with 3 different rooms on it and one in a separate house with 3 temp probes on a test rig, side by side. Both of these devices are EU with version 3,3,52,2,1 and firmware 271,4101,0.
Although they are both the same version I have often felt that one of them is more stable than the other one and that is the reason I moved it into the main building. That was actually also very good, because the other one actually already lost one of the temp sensors within 2 days or so and is now only running on 2 sensors. And as previously mentioned it happened again to the last sensor in the array.
You can see the last week graphs for both the one that was working and the one that quit.
@kwieto: I currently don?t use the digital inputs, so I personally wouldn?t mind losing out on them, but I really need to have my temperatures working flawlessly as those are critical to heating my summerhouse, but I can see the benefits of having both.
As for all sending a similar message to Vera, I am still very much up for that, just name the time and place, and if you have already sent your message I will add mine to the pool.
