Fibaro FGBS-001 question
I have FGBS-001 ( still in the box) and wondering if I can use it for the following:
-install a monostable push button ( use it as a motion sensor or so) , to send a notification and use it as a trigger
for a scene.
-install a microswitch to know if a door is open or closed.
-install a temperature sensor.
-install a ( relais to activate a) sound module.
Is this possible on 1 device , or is it or, or, or? On the manual it has some examples like 4x temperature sensors or 1 monostable push button, but it is not clear to me if I can use different type of inputs.
When it is possible to install a very simple sound module ( just needs to do a "ding dong"or “beep beep” or so) any suggestions or what kind of relais to use? I expect i can activate this sound module/relais via the UI or a scene?
Thanks,
Cor
The Fibaro FGBS supports two binary inputs (via volt-free contact closures) and up to four one-wire temperature sensors. All these are available at the same time.
The binary inputs may be configured as normally-open, normally-closed, bi-stable or momentary.
The temperature sensors must be DS18B20 types. You can connect from 0 to 4 of these. If you change the number of sensors, you must exclude and re-include the FGBS.
The FGBS does not have Z-Wave controlled outputs. The outputs that are provided switch in response to the binary inputs. I believe they would be used to replace the volt-free contacts of a security sensor in an alarm system if you used the sensor as an input to the FGBS.
When it is possible to install a very simple sound module ( just needs to do a "ding dong"or "beep beep" or so) any suggestions or what kind of relais to use? I expect i can activate this sound module/relais via the UI or a scene?
I built a simple chime/beeper using a Fibaro FGS211 and a 230V beeper. The FGS211 is set for auto-off after 500ms by setting config variable 4 to 5. I fire it from a scene that has multiple triggers. Each trigger sets a variable with the number of beeps required and the main Luup of the scene operates the beeper. I mounted the FGBS and the little beeper in a [i]wall-wart[/i] case (Maplin/Radio-Shack).
Main scene Luup:
if (beepCount == nil) then beepCount = 5 end if (beepCount < 1) then beepCount = 1 end for i=1,beepCount do luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", {newTargetValue = "1"}, 37) for j=1,50 do luup.sleep(200) if luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status",37) == "0" then break end end luup.sleep(1000) end beepCount = nil luup.sleep(2000)
Trigger Luup:
beepCount = 2 return true
I use it with 4X temp sensors and 2 micr switches witch I have mounted in doors.
They also work as scene trigger/notification.
U can use any potensial free switch or button on the inputs.
For the bell u can use the outputs on the FGBS, they are set as ‘high’ or on when the input is triggered.
Only remember that they have limited amps capacity
FYI: I found the little beeper on Ebay. They do them for several supply voltages and they have a built-in LED. They are shipped from China so take a few days to arrive. The beep is loud enough to hear if you are in the same or adjacent room without being obtrusive.
[url=http://www.ebay.co.uk/itm/150893258883?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649]http://www.ebay.co.uk/itm/150893258883?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649[/url]
