fibaro double relay switch - lighting with 2 switches
Hi All,
this is most likely a lame question but i cant find an answer (or understand one).
I have my outside house lights connected to 2 separate switches inside. 1 in the foyer and 1 in the bedroom
It means I can turn the outside lights (on verandah) on or off from either room.
I purchased a DOUBLE RELAY SWITCH FGS - 221 v1.9 - v1.10 and had my electrician install it. He is convinced that the wiring is correct and that the issue I am having is in the config of my Vera 3 / device setup.
Both switches have been replaced using LED Bell switches. I can turn the lights on from either switch but only by pressing the switch on and holding it their. As soon as I remove my finger from the button the lights will not stay on.
I can however turn them on or off for any length of time via my Vera 3 gui. Their I see 2 switches (both named _Appliance Module).
I think I am to go to the Device Options and add something to get the lights to manually switch on/off with the bell switches.
Would really appreciate any assistance.
Thanks in advance (I hope)
Peter
You need to add Configuration Variable 14 as 1-byte-dec and set it to 0 for your monostable switches. You do this on the devices Device Options tab.
Thanks Rex
For anyone else reading this I set both gui modules to Rex’s recommendations
Works like a charm thx Rex, however. I get a Device failed to configure in RED under on module.
So I removed it from one of the gui modules and all still works but no error.
Appreciate you assistance
Peter
