Fibaro Door/Window Sensor and IN Help
Hi all,
I am trying to use the Fibaro Door/Window sensor as a 12V trigger with my projector. I have wired everything and it looks positive (I see the led blink when it senses 12 V and when it doesn’t) but I am having trouble getting realtime updates from it.
Here’s what I mean, with my other Fibaro Door Window sensor, the tripping is instantaneous, but in this case, the 12V will come on a while and the sensor still will not trip Vera, it will trip on the device (LED) but not Vera.
Another weird thing is that the battery level shown is 1%, which is impossible because I just installed it 30 mins ago and it has not been transmitting a whole lot (always “Waiting for wakeup to configure device” in UI5).
My question is: is the device drawing power from the 12V trigger (which is impossible I know but how to explain the 1%?) Also, am I doing anything wrong to cause Vera not to get instantaneous response from the sensor unlike the reed sensor on my other Fibaro sensor.
Much appreciated! (=
Assuming that you did indeed wire it correctly, my suspicion would be a communication issue. Has the sensor been in situ long enough for Vera to learn routes and heal as necessary? If not, I believe that 3 quick taps of the tamper switch will wake the sensor for a few minutes, allowing time for Vera to configure the device.
It has been attached to the projector and not moved for an hour or so now. I have tried to wake it up multiple times (pressing 6-8 times and then replacing the cover) to no avail. The “Waiting for wakeup” seems to go away after some time though.
It still troubles me to see the 1% battery and the fact that when I manually poll node, the node times out.
Any clues?
Unless you get the device into stay awake mode and perform a network heal operation, an hour is not nearly long enough.
Being a battery operated device, manual polling is not going to work, as the device is asleep and will not respond to the poll.
I would expect the battery level to be updated when proper communication is established.
Either wait for the nightly heal to take place(2:00am) or figure out how to get it into stay awake mode and run a network heal.
I left it overnight, no joy. Any other ideas? (=
Thanks for the help so far.
always "Waiting for wakeup to configure device" in UI5
It isn't going to work correctly until you fix this. Wake the device up by clicking the tamper switch three times and immediately click the [b]Configure node right now[/b] button on the [b]Settings[/b] tab of the device block. Close the device window and you should see blue progress messages on the widget which finally clear. If not, repeat the operation.
Thanks again Rex. The issue has disappeared now.
Still shows 1% and still not instantaneous triggering =( the 1% really baffles me. I have excluded and included it again and it’s still the same. The device is in situ too.
Did it just go or did you get it to configure?
Did you try resetting the device as explained in the instructions? Apply magnet, insert battery, remove magnet, remove battery, insert battery - LED flashes twice.
Did you check the configuration variables? I have seen new devices with some settings not at the default values. I would add monitor only variables for 5 (should be 255), 7 (should be 255), 9 (should be 0), 13 (should be 0) and 14 (should be 0). You will need to force it awake and click Configure node right now after adding the variables.
