I’m interested to know if anyone has experienced a similar problem with any Fibaro sensor.
I associated 2 door sensors with my Vera 3. As I didn’t plan to install the sensors straight away I removed the batteries, when I replaced the batteries 3 days later, 1 of the 2 door sensors had completely lost its association. The icon remained in the Vera UI, but there was no comms. It was a simple process to associate the door sensor again, but this seems to be an odd occurrence and doesn’t seem to have been mentioned on the forum as far as I can see from searching.
Is this a known issue with Fibaro?
