Fibaro Door Sensor (FGK-101) Battery issue
hello,
does anyone know if there is a difference in the battery usage if a NC contact is used instead of the buildin Reed ?
i have a reed sensor on my Gate, connected to a Fibaro door sensor, everything works just fine, but the battery did drain empty in less than 2 months.
other sensors with buildin reed … running basically forever.
