Fibaro Dimmers controlled by scenes and physical switches issue
Hi!
I’m hoping someone here might be able to help me with a small issue i’m having and thought i’d ask the hive brain that is the internet.
I’ve got some Fibaro dimmer modules set up around the house and these are controlled by physical switches (obviously) and i’ve got some scenes set up (such as opening front door deepening on light levels and time of day it will turn the hallway light on at a level from 20% - 100%)
However the issue i’m having is that after one of the scenes has been run and i turn the light off, the next time i turn the physical switch on i’d like the dimmer to go to 100% and not the last value it was at.
Can anyone suggest anything?
I’ve tried a few things and i also can’t find any parameter to change on the modules.
Suggestions or comments?
Many thanks,
Andrew
