I just got new Fibaro Dimmer(v2.2) connected to bell-push(momentary switch) added few LED lights to it with bypass module. Controlling them through AeonLabs Minimote. I made a scene on minimote which helps me control the LED.
All works fine with remote & switch too. But the issue i face is when controlling through switch. After say around 1min+ of none usage by remote or switch , i tried to activate light using the switch & it doesn’t work at all. The only circumstances it does work is long pressing the switch, release & then fast release again twice. after that it works fine until i don’t use it for more than 1min.
I don’t under why it doesn’t function properly. Help. Urgent.
Bdw i have used almost all the previous version (v1.4 & all) but never faced this problem.
According to this post by “another user” you’re not using Vera and are instead using the minimote as the primary and only controller. As I replied to the other post, my suspicion is that a Fibaro parameter needs to be set, but I doubt that can be done with a minimote. I think you’re question would get a better answer from Fibaro or Aeon Labs.
Well i have a Vera to change the parameters of the Fibaro Module. But i don’t know which one to change. Also i have submitted this issue with Fibaro. Since its working fine with previous version of Fibaro Dimmer (v1.4) & Minimote, i sum up that the issue is with latest version on Fibaro Dimmer(v2.2).
And yea since this is a more active forum with users of Fibaro Devices & Minimote i did post here.
