Hello guys
I have the attached layout for a Dimmer with a Dimmable driver. I want to install a Z-wave dimmer.
I believe Fibaro has 2 options:
1- RGBW Controller
2- Universal Dimmer
How can i use any in such a layout?
Thank you
Hello guys
1- RGBW Controller
2- Universal Dimmer
Thank you
if you use the Fibaro RGBW controller you no longer need the LED driver. You can connect the LED’s to the controller directly. the controller also has a connector for a switch as well as a potentiometer if I remember correctly, in case you want to control it directly and not via the Vera UI
Any particular reason why you want to continue using your LED driver?
Thank you very much
I didn’t know if using the Fibaro RGBW alone is enough.
So i can connect the dimmer to the RGBW Fibaro and to the LEDs?
