Fibaro Dimmer (FDG211) + Bipass (FGB001) + LED still wont turn off completely
Hi
Have the above setup. just wired in the bi-pass.
Light not flickering with LED globe (dimmable)
but won’t turn off completely
Any ideas? I thought the Bi-pass was meant to fix this?
thanks
Where have you installed the Bypass, direct on the LED?
Just use real dimmable led light. Works fine with FFG 211.
Got Lucci LED Lux dimmable globes… non dimmable led that I had prior to getting the dimmer flickers the whole time it is plugged in
Yeah wired the bypass in to the light socket itself
What is if you change parameter 13 to 5, alternatevely to 10?
