Fibaro Dimmer Configuration [SOLVED]
Hallo All
I’m totally new to Z-Wave and co :). I have installed 3 dimmers with a momentary switch (2 wire). They work very well over the Vera Gui, but not so good over the switch. :cry:
First push → the lights going on to maximum
Second push → the lights going to minimum
third push → the lights going to maximum
and so an…
Dubble push dosent work.
At the moment i can only turn off the lights over the vera gui.
How can i fix this that the power off over the switch works?
Kind Regards
Chris
double push is used to set to 100%
you need to set parameter 15 to 1
you should also set 14 to 0 to tell the dimmer that you do use momentary switches
Hi nullx8
I made the changes but nothings changing. I can’t still not power off the the dimmer over the Switch.
Do i have to make some other changes to?
[quote=“imnuan, post:3, topic:176730”]Hi nullx8
Do i have to make some other changes to?[/quote]
Did you try to hold down the button… I’m able to dimm some Fibaro switch with TKB TZ66 switches just by holding down the push button. First long press “dim-up” if tyou release and the re-hold it will dim-down…
But I had to replace my basic switch by basic push button (3? /piece)
good luck !
are the bulbs halogens or LEDs?
the thing is that the dimmer will go down to 1 if you set parameter 13 to 1. so it wont turn off with a momentary switch. this is due to the fibaro hardware that does not do this.
Hi all
I solved the problem. Its was the Pushbutton. I had to rewire it. Now it works how it should.
Thx for any inputs :slight_smile: :slight_smile:
