New release notes says added support for Fibaro Dimmer 2 Gen5. I do not understand what this “support” means.
Fibaro Dimmer 2 Gen 5’s are not selectable as separate device types during add device wizard. I have to choose generic z-wave device. They are detected as model “FGD-212”. No gen5 there. Is that all?
Does anyone know why there are always 2 sub-devices added - apparently with no purpose?
My Fibaro Dimmer 2’s end up with “Can’t Detect Device” warnings all the time, yet the dimmer works well when polled/adjusted.Any ideas?
+1 on the Cant detect device error. I found that setting Autoconfigure device in settings to No stops the error, after clearing the “commfailure” variable under advanced tab and reloading. However I have other problems with these:
I can not get ANY bulbs to work in 2 wire configuration with the bypass 2. I replaced dimmer 1 modules with these and NONE of the 5 bulbs that used to work with the dimmer 1 now do… they all end up flickering when on. Has anyone successfully managed to get these to work with 2 wire and bypass?
One of my modules is not reporting the light as on if the switch is used… Wattage is reported, so seems like something gets back. I am not sure if this is a faulty module as others seem to report ok, as far as I can tell.
I am on the verge of sending the ones I am using with 2 wire back to Vesternet and sticking with the dimmer 1 modules.
