Fibaro Dimmer 2 showing 2 extra switches
Hello,
Ive added a Fibaro Dimmer 2 to a room with 8 GU10 lights, and the wiring is a 3 wire setup. Ive wired in the dimmer to 1 light switch and it all works fine. Lights all turn off and on and dim nicely.
After adding the Dimmer 2 to my Vera plus, I noticed that 2 extra switches appeared along with main switch. The main switch shows lighting levels and you can dim and get current wattage use. The other 2 switches that appeared are called _Dimmable light 1 and _Dimmable light 2.
Neither actually do anything, when you turn them on and off and slide the dimmer bar. And I cant delete them either.
Any idea why they are there and what they do?
Thanks.
Look for the deviceid of the devices you want to set invisible
Go to Apps ==>> Develop Apps and enter the LUUP code
luup.attr_set("invisible", 1, deviceid)
in the Test Luup code (Lua) box hit GO.
Good luck
Nice one, thanks. Worked straight away.
thx, works for me as well with the fibaro shutters
