I have just got 2 of the new Fibaro 2 dimmers and am trying to install, my first z wave devices, although I have my Vera edge setup with my alarm panel, Hue bulbs and Sonos already.
I have wired it in according to the manual, and Vesternet advice, and the device comes on and I can add it to the Vera (I used the generic device option). Its on one of the circuits of a triple gang switch, so fitting it in was a challenge. It created 3 devices in Vera and shows the energy useage. I have changed variable 20 to 1 for toggle switch (think its a different variable to the 500W dimmers)
However when I turn it on via switch or vera it comes on and then turns itself off approx 6 seconds later. Is this an issue with the setup, the wiring or the unit?
Simon
