Having problems with the second ciruit of the relay. Parent device is working fine and child is showing up but i cant get it to work at all. Is there some settings that needs to be changed?
This should work without changing any of the settings. Have you tried restarting Vera and doing a hard refresh of the web UI after including the Fibaro device? Sometimes, child devices act a bit wonky in the Vera UI when they have just been included; a restart of Vera and refreshing the browser usually fixes this.
Sorry, didnt work. Since the child device appears and act normally in UI im starting to believe its something wrong with the unit.
Did you ever find a solution for this? I seem to have the same issue with a newer type (FGS-223)
Yes, the device was broken.
I send it back to the dealer i purchased it from and got a new device, Works perfectly
