FGS221 - "Failed to configure"
My FGS221 works fine - however when Vera is reloaded it stays on “Zwave: Configuring Zwave devices” in the top-line - and “Setting user configuration” in the Fibaro module.
It stays like this for 3-4 minutes - then fails giving : “Failed: Setting user configuration”.
See attached image.
It’s only parent - child is fine.
“Configuration” parameter is “-3”. I have tried to change to 0 and “Configure node now” - didn’t help.
Anyone ?
/Martin
Have you ever been able to solve this problem. I’m having the same issue and do not get anywhere!
Rgds
Dick
Have[move] same problem[/move]. I tried everything, but ended up living with it, but will not purchase other Fibaro equipment, unless anyone sees a solution. ::slight_smile:
This is usually caused by one of: Poor communication between Vera and the device. Fix by adding powered nodes to improve the mesh; An invalid configuration variable or value. If you set them to Monitor only you will see what values the device returns. Returning nothing usually means that the variable is not supported.
