I have a few feature requests I think would add a lot of value to Veralert…
- Assign different sound, vibrate, LED blinking settings per alert.
- setting should be in the Notification section on the Vera app, on the same line where you can customize the message.
- specific use case: will allow you to assign ‘louder’ sounds to more urgent notification, and no sound to unimportant ones - like Vera Resets
- “Security / Vacation Mode”, per device.
- makes the Android app continue to bug you (sound, LED, vibrate) until you acknowledge.
- Example: motion detector is tripped when you were on vacation but you did not notice the alert. The app keeps bugging you until you do.
- On-Screen popup, on/off per alert
