And the second is an option to send an alert without notification
{notification:N}
for example if you just want to execute tasker task without notification, or when I’m using autonotification (Plugin for tasker) that have a lot of options and even actions, so I send the alert with vera alert, and execute notification with tasker that have action, so when I use tasker notification I don’t need the vera alert notification just to execute tasker task
Currently the Vera Alerts Tasker interface allows you to call Tasker when a specific Vera Alerts notification is received. So if I disable notifications … Tasker will not be able to see any … just specific ones.
Tasker can see any Android level notifications (not just those from Vera Alerts)
Because of the loose binding nature of Tasker (it does not react immediately) … If I auto clear (cancel the notification) … it very well may not see the notification.
If you can add this option as a task in tasker it will be great, so in the start of each task you put the “clear veralert notification” and than you can continue with the task, this way it will clear the notification of veralert only after starting the task
also wanted to know where can I find the latest files to translate the app?
