Like the title says, it would be great to have AutHomation try to resend failed commands. The ability to specify retry interval and timeout would probably also be a good idea.
Unless it already does this?
I originally had to it resend the command a second time if it failed. I removed the code, but will add newer code to retry several times if the command fails to send.
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
