[feature request] add dimmer level trigger
Would it be possible to add an extra trigger option?
Add dimmer level trigger:
If dimmer level is X% then trigger activate
Hope this can be added the near future…
You can do this in PLEG using a Device Property Input (in this case the dimmer level) and a condition
i.e.
Input:
Dimmer1Level Select the Dimmer level of the appropriate device (note there is a slight difference between the Target and Level)
Condition:
DoSomething Dimmer1Level > 30
Add Actions to DoSomething similar to adding actions to a scene.
Thx,
But i wished it was standard possible (witout extra tools/plugins) directly in the scene itself.
Switch, sensor (motion, battery, lux) is already possible, so why not dimmer level…
As a developer you can modify the appropriate JSON file to add this ability … but this is a system level file and will get wiped out on future updates.
