Garrett,
I was hoping you could update the app to support using the user codes inside the Plugins, so we don’t need to type it into AHHD?
Talking with Cybrmage…
[quote=“cybrmage”]Actually, for the record, the arm mode routines are still largely unchanged from the original code - which was based on the AD2USB plugin…
The RequestArmMode UPnP action requires three parameter - requestArmMode(device, State, PINCode)
The RequestQuickArmMode UPnP action requires three parameter - requestQuickArmMode(device, State)
The code actually ignores the provided pincode for the RequestArmMode command and uses the pincode stored by the plugin… The RequestQuickArmMode command actually calls the RequestArmMode function with “nil” as the third parameter…
So, any changes he makes should be applicable to both plugins…[/quote]
