Fan coil Z-wave thermostat
Hello All,
I have objective to control my fan coil through z-wave.
How can I solve my problem.
Please advice me what to do.
Thanks.
I have faced the same problem.
Can anyone help me solving this?
I have the Honeywell Z-wave and i don’t think it will work to do that. I’m thinking to install a Z-Wave relay in my furnace to start the fan independently of the thermostat stat settings.
The Z-wave Honeywell definitely has a fan contact that will cycle the fan with heating, cooling, recirc or continuous.
The G terminal (C terminal is the common) of the stat will supply 24vac when a demand for the fan is made.
Yeah, I know I can control the fan from the thermostat interface directly (like most thermostats), but I have not found a way to control the fan remotely via the Vera app or web interface.
I’m not picking up what your putting down.
So can you see the thermostat on the vera app or automation app (android)?
eg. mode - heat, cool, auto
fan - auto, on, cycle
heating set-point
cooling set-point
Here is how my H/W stat displays in vera
I have the Honeywell Z-Wave thermostat and run UI7 (which came with or immediately updated to when I first setup Vera3). I use the Vera 7 Android and iOS apps and I only have the following settings:
-Temperature control - up and down
-Operation Mode: Off / Cool / Heat
I’d be extremely interested to figure out how to have more settings like: fan, programming modes (schedule, energy savings), etc.
[quote=“mr crewcab, post:6, topic:173190”]I’m not picking up what your putting down.
heating set-point
cooling set-point
Here is how my H/W stat displays in vera[/quote]
You need something like this:
[url=http://automasys.persiangig.com/Smart%20Control%20%DA%A9%D9%86%D8%AA%D8%B1%D9%84%20%D9%87%D9%88%D8%B4%D9%85%D9%86%D8%AF%20%D8%AF%D8%B3%D8%AA%DA%AF%D8%A7%D9%87.jpg]http://automasys.persiangig.com/Smart%20Control%20کنترل%20هوشمند%20دستگاه.jpg[/url]
کنترل هوشمند دستگاه برقی توسط گوشی هوشمند و تبلت اندروید
I’d like to do the same thing. If Honeywell would add Z-wave to the equivalent of the TB6575 or TB8575 with MiCasaVerde support then the problem would be solved. The only other thermostats I can find for fan coils that are Z-Wave ready are
http://www.evolvecontrols.com/devices/environmental/glass-t100h
http://www.mcohome.com/index.php?m=Product&a=show&id=12
https://www.nuuon.com/eshop/pdf_datasheet.php?products_id=878
http://www.cebit.de/product/thermostat-mh8-fc-eu/460454/X137759 (EU voltage)
None seem suitable for MiCasaVerde or I can’t find enough information.
