Hello, I recently got a system restore by MCV tech support. And anytime I try to pair a kwikset door lock I get this error… Failed to go in learn mode… I can include other zwave devices but the doorlock. Any suggestion on how to fix this?
Hello, Can you please submit a trouble ticket from the Vera web interface so we can investigate your issue.
Thank you.
I have the same problem. MCV reset zwave version to 2.78 instead of 3.20 to make my danfoss thermostats work and then I had difficulties including other divices. MCV put it back so I was able to include and put it back afterwards.
This is not a good solution, please fix it.
CE
[quote=“mcvchris, post:2, topic:179657”]Hello, Can you please submit a trouble ticket from the Vera web interface so we can investigate your issue.
Thank you.[/quote]
Sure, sry was on the road
I opened the ticket this afternoon but still dont have any answer… i just got home and tried to pair again. lol
still no luck.
Exactly what i was doin… still no luck :-[
Hi Javier,
I?ve managed to access your unit by ssh. I can see a lot of Z-wave traffic generated by device #15 (Switch EM Tv). Can you please tell me the manufacturer and the model number for this device? Can you try to disconnect this device from the power and then try again to re-include the door lock?
Door locks are a special breed of Z-Wave devices which require an exchange of security keys with Vera during the ?Include? (?pairing?) process. That?s why we recommend to have Vera at about 3 feet ? 5 feet from your door lock at the Inclusion process. We recommend to use the Full Power Inclusion:
http://docs5.mios.com/doc.php?language=1&manual=1&platform=3Pro&page=full_power_inclusion
After the inclusion process finishes you may move your Vera to its final location, but if the distance between them is more than 20 ? 30 feet, you must have other Z-Wave devices that are security capable. These devices will act as repeaters, and the encrypted signals from Vera will reach the door lock and vice versa.
First you will have to exclude the door lock. You will need to put your Vera in Full Power Exclusion Mode and follow the steps:
remove the batteries from the lock; - press the program button 3 times to reset the lock; - reinsert the batteries; - wait for the red light to go off; - press the button in the top left of the lock.
Then please put Vera in Full Power Inclusion Mode and follow the steps: -
After you have managed to include the door lock you must leave Vera about 10 minutes close to the door lock to let it finish the configuration process.
Please let me know how it goes.
Still nothing
