After I heal the network I often get “Failed at: Setting special association” this from a number of devices. After I have manually used “Configure node now”, polled the device or turned it on/off it often starts to work again
What does “Failed at: Setting special association” mean and how come it happens so often to me?
Is there something I can do for these devices configuration wise?
It happens to devices that function properly all the time except for when I have done a healing on the network
Regards,
Mikael
