I needed to set Vera2 to factory defaults, so I performed factory reset, by pressing twice quickly the reset button on the back of Vera2. The procedure didnt work correctly, the system seemed to reboot and make some operations, with some lights switching off and back on after a while.
However, when I load the web interface, the configurations are not erased, and nothing is set back to default values.
I read in the forum that this seems to be a known issue.
Someone suggested executing in console the following script:
/usr/bin/cmh_Reset.sh all
By doing this, my SSH connection is cut and the script does not follow execution from that point on, so I tried instead:
/usr/bin/cmh_Reset.sh all &
so that the script completely followed execution after closing network interface. In this case, what I get is the same procedure and result than by using the reset button.
Summarizing, something seems to be wrong with the Reset script that is launched by using the reset button. I’m newbie to Vera so I doubt a lot I have enough Vera knowledge to troubleshoot that script.
Is there any known solution to this?
Particularly, I need to set my Vera2 as primary controller since at the moment is set as SLAVE, and no options from the web UI (like resetting Z-Wave network and so on) are helping on this issue. If there’s no solution to this, that means that once you set Vera2 as slave it will be stuck to that role forever and it will never be possible to use it as primary controller!
Help would really be appreaciated!
Thanks a lot
and best regards.
