EZMotion and Degree Celsius - Precision
Hi there !
I’d like to know if it s possible to have an tenth degree precision when using this device in Degree Celsius ?
So far, i only have a unit degree precision when getting the temperature of my room.
Cheers
@CedGex,
Welcome!
I believe the device supports it, but Vera does not.
I have the same guess.
People who use it in Fahrenheit, is it the same problem for you ?
Any possibility to make it work bu lua code ?
Full degrees only.
There is no access to the higher precision number.
(There are some previous threads on this; and the request to MCV has been made several times. Not sure where this is on the priority list.)
Temperature resolution for the HSM100 is 0.2 °F / 0.125 °C (according to the manual).
[tt]ZWave API - LinuxMCE
