Has anyone tried to change parameter 7 Tempadj?
I think my sensor is showing too high temperature, but i cant figure out how to change this setting, im using Celsuis.
Vera3 UI5
Vera3 UI5
Have you tried setting 1 byte, dec with value 246, for instance, to see -1.0 (F) adjustment (on the [tt]Device Options[/tt] tab of the parent device)?
I see some change when i do that, But i can only put in + numbers. How would i type a negative number -20? When i try to do that it tells me to put in a 1byte dec number.
Ah i understand now, i think i have to read up on byte and bit’s ;D
