EZMotion 3 in 1 settings help
Hi
Just bought 2 of these and am really struggling to get them working reliably. I have the recommended UI5 firmware and the MIOS update utility. After some time I now get the temp sensor so must have the correct XML. However I am struggling to get the motion detector to work correctly. As far as I can tell I have set up properly per the wiki. It seems to show motion persistently even when there is none. I have set wakeup to 60s, poll to 60s and am now powering from mains in case that helped, so set stayawake to 1 and On time to 0.
Would appreciate any advice and / or sample settings for someone who has this working properly - both on battery and off.
