We’ve updated all Vera Edge controllers that are enrolled in the pre-Alpha testing group with the Ezlo Linux firmware v.1.0.16.
To get the update you need to do one of the following actions:
- Power cycle your Vera Edge controller or
- Unplug the ethernet cable, wait 10s, plug it back into the Vera Edge controller.
Please note the update takes few minutes to complete (~10 min).
New features:
- Advanced Scenes - added support in the Firmware for AND, OR, NOT logical operators and new type of action: Change House Mode. Please note that this feature will be available together with the Beta mobile apps for Android and iOS.
Improvements:
- Added support for using pin codes in scenes by adding the possibility create scenes that are triggered by Pin codes being entered.
- Improved the devices migration flow during the Firmware upgrade process.
Fixes:
- Bug fixes and improvements on creating scenes that are triggered by other devices and use scene controllers as triggers in scenes.
Newly integrated devices
Ezlo Bulb B-2700-6W-A19-US (No DPW)
Neo Coolcam Z-wave Plus Water Leak Sensor NAS-WS01Z
Dome Z-Wave Plus Leak Sensor DMWS1
Jasco ZW4009 In-Wall Smart Switch (No DPW)
Aeotec Siren ZW080
Neo Coolcam PIR Motion Sensor NAS-MS01Z (No DPW)
Everspring Outdoor Motion Detector SP816-2 (No DPW)
Inovelli LZW30 On/Off Switch (No DPW)
Aeotec Siren ZW080
Newly integrated devices with known issues:
GE 14285/ZW4007 Direct-Wire Outdoor Smart Switch (40 Amp) (No DPW)
Everspring SE813 S2 Multisiren (No DPW)
Aeotec ZWA008 Door/Window Sensor 7 (No DPW)
Everspring ST812 Flood Sensor (No DPW)
Philio Flood Multisensor PAT02-A (No DPW)
Philio Flood Multisensor PAT02-2C
Fortrezz WWA-01AA Wireless Water & Freeze Alarm
Fibaro Flood Sensor FGFS-101 GEN5
Fortrezz FTS05 Flood and Temperature Sensor
Fibaro FGDW-002 Door/Window Sensor 2
Ecolink FLF-ZWAVE5 Flood/Freeze Sensor
Ring 4SF1S80EN0 Flood Freeze Sensor
Aeotec ZW141 Nano Shutter
Neo Coolcam NAS-SC03ZE-2 Curtain Switch
Known issues on newly integrated devices:
- Issue affecting GE 14285/ZW4007 Direct-Wire Outdoor Smart Switch (40 Amp) where a scene with “release button action” is triggered after a scene with “button pressed X times” action is performed.
- Issue with unnecessary child device being created for Aeotec Door/Window Sensor 7 ZWA008
- Issue on Philio Flood Multisensor PAT02-A, Philio Flood Multisensor PAT02-2C and Fortrezz WWA-01AA Wireless Water & Freeze Alarm flood sensors triggers are not present in device trigger list when creating a scene and scenes with triggers are not running for flood sensors
- Issue on Fortrezz WWA-01AA Wireless Water & Freeze Alarm and Fortrezz FTS05 Flood and Temperature Sensor with a heat sensor being created after adding the device.
- Issue on Fibaro Flood Sensor FGFS-101 GEN5 where after inclusion the flood sensor is added with 2 additional children sharing the same functionality and name
- Issue on Everspring SE813 S2 Multisiren with a power state device being displayed on the app after the inclusion.
- issue on Fibaro FGDW-002 Door/Window Sensor 2 with Two additional children are added after the inclusion process.
- Issue on Ecolink FLF-ZWAVE5 Flood/Freeze Sensor with an additional device (freeze sensor) being created with no support in the firmware/UI/cloud for this type.
- Issue on Aeotec ZW141 Nano Shutter with missing device triggers and missing button numbering in scenes creation.
- Issue on Aeotec ZW141 Nano Shutter with the Roller shutter device cards having an on / off switch.
- Issue on Neo Coolcam NAS-SC03ZE-2 Curtain Switch with roller shutter device cards having an on / off switch and with the the icon for roller shutter on iOS app that disappears from the app interface when the device it’s controlled from the physical OPEN button.
Other known issues:
- Issue with no events being generated when tampering a security sensor;
