EZ 3in1 Sensor - what happened to the brightness sensor reading?
after the latest upgrade to LUUP, the brightness readings from the 3in1 sensor does not seem to be recorded anymore. The sensor is set with a wake-up interval of 3600s. Before the upgrade, FindVera used to display the latest reading on the Dashboard and Device page - now it doesn’t (just says OFF). The temperature reading from the same sensor gets recorded like before the upgrade. This is not a critical functionality to me (the temp and motion is), but it triggers my curiosity when something that used to work does not work anymore;-)
Anyone knows?
I do believe this issue has been raised elsewhere in the Forum, perhaps in a couple of threads. And I’ve heard that an upcoming firmware update will address this and other sensor/temperature-related shortcomings.
