Every time I open a window or door, vera triggers multiple alarm sensors fire alarm, co detector and motion sensors, not all trigger but the same ones always do. I cant figure this out.
I would like only the devise that triggers to trigger in vera. My EVL and alarm panel are working normally so that is not the problem.
Also, I uninstalled the plug in and reinstalled and retested with only 2 sensors and had the same issue. The Fire zone was tripped when I opened a door. In addition, the Honeywell alarm panel and the EVL4 are all reporting 100% correctly in their own portals and no issue there.
For example, when I trip the window sensor “29 Door Attic”, the following sensors also trip, which should not happen:
01 Fire
02 Motion Sunroom
06 Motion Family
04 CO Detector
05 CO Detector
09 Heat Det Gar Att
10 Heat Det Gar Sun
11 Sm Heat Det Gar
But the other 20 some zones are normal and don’t trip unless I intentionally trip them.
Does anyone have any idea what is wrong?
Thanks!
