Since two months I am a very satisfied user of a Vera2 and several Zwave components, started out with two dimmable light switches and yesterday I received my 3in1 sensor and another non-dimmable light switch (for a already dimmed light), I found out that it is not possible to activate a device or a scene over a certain period of time, I think this might be a very good thing to include in a next firmware release, unless somebody has some other idea’s of course… I tried to do so for the light senstivity function of my new 3in1 sensor, I would like to make it function (poll) during a certain period of time, for instance from 18:00 till 24:00 if level of light is <10 then turn on light.
create a new scene under automation (for turning on the light)
under devices, find the light and choose to turn it on.
under triggers, choose your light sensor, select brightness reached < 10
this way the light will turn on whenever the brightness is less than 10. In order to add the time restriction:
under LUUP add this code (to prevent the scene from running if the hour is less than 18)
local t = os.date('*t')
if (t.hour<=18) then
return false
5. Save Lua and Confirm changes.
At this point, you created a scene to turn on the light. You need to create the scene to turn it off, depending on your need (for example, turn it off whenever light level >10 or whatever)
