First of all, I decided to do a fresh install. That seems to have been unnecessary, but nonetheless it is what I have done.
My Lite was (and still is on) UI5. When I installed the Plus, I was prompted to create a new account. I entered my old account information and it created a new account. This has now created a problem with having what I would call a UI5 and a UI7 account with identical usernames and email accounts. I must advise anyone else trying this to avoid this as it has caused many problems – the most immediate of which was not being able to log into my Plus except with one browser on one computer which apparently stored some information in cache. Eventually, what I needed to do was a create a new account with a new name and different email. This at least allows me to log onto the Plus from any browser and SOME android apps.
1.A. – Does anyone know if there is a way to delete an account with Vera?
1.B. – IF an account cannot be deleted, is there a way to associate 2 different usernames with the same email address?
Garrettwp’s outstanding AutHomation app was not working for me on UI 7 in remote mode. I understand it is not underdevelopment anymore as Garrett has moved on, but this was disappointing. It took me a bit of time to get it going, and I think I have solved the issues. If anyone else is having this issue, post here and I will try to help you. I am not 100% I have solved this, but if you are playing around with it, I would suggest your download the latest beta and read the information at the end of the Beta thread for help.
Experiencing some issues with basic PLEG actions. Very simple stuff – Motion turns on light, then X minutes later, the light should go off. I can get the light to go on, I just cant get it turn off after the delay. Unclear why this doesn’t work when it worked perfectly under UI5.
Why would you use pleg instead of a scene for a simple light timer like that? Pleg seems like overkill for that.
Sent from my XT1585 using Tapatalk
[quote=“JasonJoel”]Why would you use pleg instead of a scene for a simple light timer like that? Pleg seems like overkill for that.
Sent from my XT1585 using Tapatalk[/quote]
I thought PLEG was the only way to do anything like that to be honest. But, that simple action was meant to be part of a something more complicated which I have not gotten around to yet.
Also, that said, I think have had better luck with other PLEG actions I have tried subsequent to my post. I can probably solve this problem by simply deleting the offending item and trying again.
My concerns remain about the account issues. I have further discovered that authomation seems to work sometimes and not work other on remote connections.
Here is luup code I use as on a minimote to toggle a lamp next to my bed. If the light is on, it drops it to 70% brightness and then slowly dims. If it’s off, it goes to 10% brightness and ramps up to full.
My lamp id is 40. change as you need. I think this has some extra variables I never cleaned out but c’est la vie.
local device=40
local delay=10
local mindim=0
local maxdim=100
local counter=0
local counter_max=11
local switchOnOff = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”, “Status”, device)
local lightLevel =luup.variable_get(“urn:upnp-org:serviceId:Dimming1”, “LoadLevelTarget”, device)
if (switchOnOff == “1”) then
lightLevel=70
– Switch is on
while (lightLevel >=0) do
luup.call_delay( luup.call_action(“urn:upnp-org:serviceId:Dimming1”, “SetLoadLevelTarget”, {newLoadlevelTarget = lightLevel}, device) ,delay)
lightLevel =lightLevel-1
else
lightLevel=10
while (lightLevel <100) do
luup.call_delay( luup.call_action("urn:upnp-org:serviceId:Dimming1", "SetLoadLevelTarget", {newLoadlevelTarget = lightLevel}, device) ,delay)
lightLevel =lightLevel+1
[quote=“Wekurtz74, post:1, topic:191323”]First of all, I decided to do a fresh install. That seems to have been unnecessary, but nonetheless it is what I have done.
- My Lite was (and still is on) UI5. When I installed the Plus, I was prompted to create a new account. I entered my old account information and it created a new account. This has now created a problem with having what I would call a UI5 and a UI7 account with identical usernames and email accounts. I must advise anyone else trying this to avoid this as it has caused many problems – the most immediate of which was not being able to log into my Plus except with one browser on one computer which apparently stored some information in cache. Eventually, what I needed to do was a create a new account with a new name and different email. This at least allows me to log onto the Plus from any browser and SOME android apps.
1.B. – IF an account cannot be deleted, is there a way to associate 2 different usernames with the same email address? [/quote]
Email support@getvera.com from the email address you want deleted and give them the username also. It will take a few days for them to get to it but that’s what I did.
