I purchased 4 new door sensors and when I added the devices to my Vera Plus I got the following message:
Expected device was Ecolink Door & Window Sensor - ECO-DW (PK_KitDevice: 2194), but you have paired a different one (Ecolink Door/Window Sensor - DW-ZWAVE2.5-ECO - id: 6311).
However, you can name it and assign it to a room.
The problem I encounter was when I tried to use the sensor in Reactor I could choose it but there was no Tripped condition to pick to use the sensor in the condition.
I was able to use the sensor in a scene and that made the Tripped condition available in Reactor. I had to do this for each of the four sensors.
