Excluding a Popp Plug
Hi
I’m having difficulty re-adding a Popp plug into my Vera. I’ve had it included in the past but deleted it while testing ui7. The instructions say including and excluding is the same process, cluck the button 3 times but nothing happens. I’ve pressed the “-” on the Vera and clicked the button 3 times then the “+” and the button again but it doesn’t add.
Am I doing something wrong?
EDIT - I’ve managed to exclude / include using battery mode :slight_smile:
I know there was a option in UI5 to manually exclude, not finding that option in ui7
I have not needed to use it, but in case I ever do, would be nice to know where that option is if anyone knows
