Example of luup files for IR
Hi everybody,
Could anybody be so kind as to provide me with some example of the files I need to use USB-UIRT to control devices? I have the HEX-codes needed, but can not figure out how to do the XMLs - examples would help a lot.
Thanks,
Andreas
What are you trying to control?
The best bet is to create one from the limited ones there are in the database; If its a TV then obviously pick a TV to make the function types (volume etc, channel etc) as close as possible, it’ll download and create a plugin for you; after thats done, download the xml it created, and you can copy and paste your new pronto codes into the implementation xml (replacing the original codes like for like). Once complete then upload it again.
