EVR_ST814 trigger ON/OFF not showing up (UI7)
I have set up the EVR_ST814, so far I got this working:
  • sent the new value when there is a change in 1 degree or 5% humidity.
  • sent an update every half hour
But no matter what I try I don’t see the values I have to for the triggers ON/OFF.
I have set them manual on the device and also via parameters, but that’s the same.
I hear an alarm beep, but…the GUI in my Vera Edge is NOT updated.
So a scene to start my ventilation doesn’t start.
So far I set it to sent 5% changes and start a scene when the value goes above X,
but that is not what I want.
Would be great if I could get some info/help. Thanks.
Any one please?
Hey I’m not clear what you’re trying to do from your question, but I have a question for you:
How did you set your reporting up? I can find instructions for ui5 but no ui7. I assumed I had to create new variables. So I went in to do that, created 6 with a value of 0, but I don’t see it listed with the other variables ans I can’t add more (7 & 8) on the page where you create the new variables.
